HELP!!!!
Old Nov 21, 2008 | 09:04 PM
str8upclownen's Avatar
ML350
HELP!!!!
OKAY, SO TODAY I GET IN MY ML320 (1999) START IT AND THE LOW RANGE LIGHT BLINKS A COUPLE OF TIMES SO I TRY AND TURN IT OFF, AND CHECK TO SEE IF I DID BY TURNING THE CAR OFF AND ON AGAIN TO SEE IF IT WORKED, IT DIDN'T SO I DID THE SAME THING AGAIN AND WHEN I TURNED IT ON THE SECOND TIME THE CHECK ENGINE LIGHT CAME ON???? AND THE LOW RANGE WAS STILL BLINKING???? ANY HELP APPRECIATED THANKS STEVE P.S THE LOW RANGE LIGHT ONLY BLINKS WHEN I TURN ON THE SUV AND THEN GOES AWAY AFTER LIKE A COUPLE SECONDS? AND NOW THE CHECK ENGINE LIGHT STAYS ON EVERY TIME I TURN IT ON AND STAYS ON???? THANKS AGAIN STEVE
Old Nov 22, 2008 | 01:50 PM
ML350
UPDATE
OKAY SO TODAY I GET IN AND THE LOW RANGE LIGHT JUST BLINKS AND THEN GOES AWAY, AND NOW THE ENGINE CHECK LIGHT WENT AWAY????
Old Nov 22, 2008 | 06:09 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
WHY ARE YOU TELLING... STOP YELLING IT HURTS TO READ WHAT YOU WROTE
BTW, I WOULDNT DRIVE THE CAR IF IT IS STUCK IN LOW RANGE. IF ITS REALLY IN LOW RANGE YOU COULD DO LOTS OF DAMAGE TO THE TRANSMISSION
so get it checked out by a dealer or qualified mechanic... and have them read the codes... ASAP
Old Nov 23, 2008 | 03:20 AM
ML350
CAUSE I THOUGHT SOMEONE HERE COULD HELP?, AND IAM NOT SURE IT STUCK IN LOW RANGE JUST THAT THE LIGHT BLINKS FOR A COUPLE OF SECONDS WHEN I TURN IT ON????
Old Nov 23, 2008 | 08:03 AM
Stiggs's Avatar
2003 CLK55
CAP LOCKS FTL!
Old Nov 24, 2008 | 09:39 AM
55fanatic's Avatar
Originally Posted by Stiggs
CAP LOCKS FTL!
I AGREE, OP SHOULD STOP USING CAPS LOCK AND CONTINUE TO DISCUSS LIKE NORMAL NON YELLING ADULTS!!!
Old Nov 24, 2008 | 09:42 PM
ML350
okay, didn't know it meant yelling,
WOW ****ING WOW!!!!
Old Nov 25, 2008 | 11:02 AM
55fanatic's Avatar
bout time... are you pulling any codes? or does the low range just blink and then stop?
try putting the car in to neutral and switching in to low range, and then try coming out... maybe something needs to reset itself?
Old Nov 25, 2008 | 07:42 PM
ML350
the low range just blinks (for a couple of seconds,and only at start up?) and then stops?
Old Dec 7, 2008 | 07:33 PM
Stiggs's Avatar
2003 CLK55
WOW ****ING WOW!!!!
Yeah, we're hard @sses, but in the end it makes you tougher.
Old Dec 8, 2008 | 03:37 AM
ML350
hehehe
Old Dec 21, 2008 | 03:45 PM
prostovito's Avatar
mercedes ml 430
ok here is what you do to fix the problem. turn the car on let it blink and than stop. put it to neutral and turn on your low range. the indicator light should stay on meaning it turned on. than drive the car around the block just lightly at like 5 mph. than tun the low range of. and turn of the car. after this your problem should be solved. what happens is the low range sensor gets out of position and its blinking by letting you know. and after you drive it, it find its space again. well good luck man.
Old Dec 22, 2008 | 02:42 PM
ML350
prostovito thanks alot man will try it today....
