Thoughts on odd sound?
Old Dec 12, 2008 | 08:15 AM
Gustaf's Avatar
1990 300TE
Exclamation Thoughts on odd sound?
This has me a little baffled. I'm getting an intermitent CEL, (p0105) maybe o2 sensor, but the wierd thing is this noise I'm getting. It sounds like an exhaust leak on the drivers side, but I can't duplicate it in my garage, it only makes it underload out on the street. The best I can articulate the sound is as a exhaust leak. Any thoughts?
Old Dec 12, 2008 | 01:33 PM
00ML430 Bulldog's Avatar
2000 ML430
Cracked catalytic converter
Old Dec 12, 2008 | 02:03 PM
Gustaf's Avatar
1990 300TE
Possibly but I have been up and down the exhaust and seen no tell tale signs
It is just the fact that it only makes it under load that bugs me
Old Dec 12, 2008 | 05:40 PM
2000 ML430
I've been there done that. Common failure. The symptoms were the same as you described. There is a recall for the cats on some year model ml. Mine cracked years back. They were replace by the dealer under warranty. Have a professional check your cats, the ML has two cats.
Old Dec 17, 2008 | 12:58 PM
Gustaf's Avatar
1990 300TE
Yup I found it, drivers side hair line down the weld. Anyone else have this on an ML500? I have it set up to see the dealer tomorrow, so we will see if they step up
Old Dec 17, 2008 | 01:39 PM
2000 ML430
Good deal. Keep us updated
Old Dec 18, 2008 | 04:11 PM
Gustaf's Avatar
1990 300TE
Update- This should help for all ML500 owners, our cats are covered by the 10 year or 80k miles warranty, so even though our trucks are not mentioned in the "recall" if they crack MB will replace. Mine has 52k on it and both sides are being replaced as I type.
Side note the SMART makes my coupe look rather low slung
Old Jan 8, 2009 | 08:23 AM
2000 ML430
Nice rides. Glad it worked out.
Old Jan 9, 2009 | 11:35 AM
Gustaf's Avatar
1990 300TE
Thanks Bulldog
