Tips on Buying a 1998 ML320???
Old Jan 17, 2003 | 02:18 AM
sLickfITY's Avatar
Question Tips on Buying a 1998 ML320???
I am in the process of buying a 1998 ML320 w/75,000 miles. i checked out the car and i could tell it needs a valve adjustment, they ran a Carfax report for me and it all checked out good but you cant really trust that report alone. How much does this valve adjustment service run for at a certified MBZ mechanic? They are asking $17,900 which fairly reasonable but i am kinda iffy about the engine. they are offering a 3yr/35k mi. warranty for 2k extra on top of the sticker. Can any of you guys tell me what i should look out for next time i check out the car? Thanks this would be greatly appreciated.
Brandon
Old Jan 17, 2003 | 02:35 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
The ML320 has self-adjusting valves that never need adjustment. What kind of noise are you hearing?
Old Jan 17, 2003 | 03:16 AM
sLickfITY's Avatar
im hearing a constant ticking noise when i start the engine up. what could this be?
BTW:thanks for your reply
Old Jan 17, 2003 | 10:03 AM
mbtech208's Avatar
All of the SOHC V6's and V8's have some degree of a "tick-tick-tick" at idle, which is the sound of the fuel injectors clicking open and closing. This may be all you're hearing, though I'd have to hear it to be sure.
Old Jan 19, 2003 | 02:53 PM
Chuck V's Avatar
ML320, C230k Coupe, C240 4MATIC
Sounds reasonable, but take the warrenty.
Haven't looked at prices on the 98. Check out the blue book price to see if its a deal or not. Don't even think about a 98 though without a good warrenty.
Old Jan 19, 2003 | 10:09 PM
DougWW's Avatar
ML430
Kelly Blue Books shows this to be 13,900-14,000 as a private party sale and 17,900-18,900 retail. The 98's had a lot of problems, rear tail gates that rattled, fuel pumps that just stopped working without notice. Keys that failed, and a host of other problems. You might be better off looking at a 1999 or later when a lot of these problems were solved. I have a 99 and have had the fuel pump problem and door locks that failed.
Doug W.
Old Jan 19, 2003 | 10:27 PM
sLickfITY's Avatar
Post
well i am going to buy the 3 yr 35k mi warrenty for it. i may just keep my options open and still look. Everything seems to work fine when i check it out (knock on wood).
