Hesitation 2000 ML320
Old Feb 20, 2009 | 05:45 PM
rskinner's Avatar
2001 C240/2000 ML320
Recently my 2000 ML320 started hesitating when accelerating after a cold start. Within 30 seconds or so the problem goes away. The car has 80,000 miles and changing the spark plugs didn't help.
What else should I look at? No CEL, so nothing to read with my scanner. I'm thinking maybe the EGR or a vacuum leak?
Old Feb 21, 2009 | 03:25 AM
STi_JL's Avatar
02 W163
Alternator, starter, battery, misfiring, may be some possibilities
Old Feb 22, 2009 | 09:58 PM
rskinner's Avatar
It's strange since it clears up in less than a minute. I thought a misfire would trigger a CEL, and there is no rough idle if there was a misfire.
Seems like there is a lack of fuel as it limps along (idles okay) , then all of a sudden it is fine. Any ideas would be welcomed, I really don't want to take it to the dealer. Thanks.
Old Feb 22, 2009 | 11:36 PM
STi_JL's Avatar
02 W163
mis firing does idle liekthat, but you can easily tell if its mis firing,
the engiee would sound like a harley davidson.
im guesing alternator.
