Need help determining if my driveshaft u-joints/center support bearing are cause..
Old Apr 20, 2009 | 01:08 PM
croat's Avatar
02 ML320
...of the noise.
Here's the bit of history
2002 ML320 with 120k kilometers.
Recently we noticed that car would occasionally start making scraping/grinding noise that's coming from middle to back of the truck. Seems to increase with speed of the vehicle. The noise wasn't constant.
We looked around and thought it was the e-brake shoes. Took the rotors off and the pads were in rough shape, with some pieces chipped off. Thinking this is a def cause, I ordered new rotors, e-brake shoes and pads. Installed it but grinding noise is still there. Now it's constant. Thinking I might have messed up something with e-brake shoes install, I took them off completely, put rotors back, drove it. Still the same constant grinding noise.
Took the SUV to local non-MB garage. They lifted the car up and got the wheels spinning and there is no noise.
Owner of that garage thinks it's something related to driveshaft, where driveshaft gets loaded when you actually drive the car. Either rear ujoint (that connects to rear diff) or center support bearing.
He asked me to take the driveshaft off myself (to save money on labor) and he will inspect it.
Do you guys think this is the cause?
Old Apr 20, 2009 | 03:28 PM
croat's Avatar
02 ML320
Would this cause the grinding noise? lol
http://www.youtube.com/watch?v=UWazPz-IPQk
I checked this bearing few weeks ago, when noise was intermittent and wasn't clunking but had some movement. Now that noise is constant it and I get this crazy movement/clunking, I believe this is the cause. It would be good if you guys could confirm before I order replacement.
Also, does someone have a link to good DIY, with pics and torque specs?
It looks fairy simple to remove the driveshaft. I might have to take it to the shop to press in the new bearing tho.
TIA
Old May 8, 2009 | 08:56 PM
Avec's Avatar
I don't think it would cause a grinding unless there was a total center support failure. In any case, check it out. It is easy enough - just check it for wiggling. Grab the drive shaft from it to the rear end and see if it is loose at the center support. If it is, it is easy enough to replace - no pressing required. I did a write up a while back when I replace one. If you cannot find it, let me know and I will try to remember the tricks.
