Code P0123...no acceleration at all. ML500
Old Sep 21, 2009 | 03:14 PM
boosoo's Avatar
C230 Coupe
2003 ML500. Starts out driving fine, then after a few minutes loses power and does not accelerate at all. You can push the pedal to the floor and lucky to go 10mph. If I kill it and restart it is fine for a few minutes, then happens again. No other lights other than the check engine, and no other codes other than p0123. I've searched and found a similar problem with the S class, and it was the actual pedal module. Anyone have the same issue?
Old Oct 1, 2009 | 03:20 PM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
Throttle Position Sensor, happened to me driving on rt 95, after dodging the traffic and almost crapping my pants!! I pulled over restarted and it ran OK as long as I did not go WOT until I got it home.
Cost $134.33 it's a do it yourself install it's located on the firewall next to the fuse box. http://www.partsgeek.com/catalog/200...on_sensor.html
