98 ML320 Climate Control Panel Lighting
Old Sep 21, 2009 | 09:40 PM
Spicoli's Avatar
Ml320
Can anyone help me determine why the backlighting has quit working? Thanks
Old Sep 21, 2009 | 11:46 PM
FraKctured's Avatar
W203-4M W163
Because it's 12 years old and needs a new fuse or new bulbs or new sensors in the doors.
Old Sep 22, 2009 | 08:49 AM
Spicoli's Avatar
Ml320
Thanks but that's my problem. Does it have bulbs or integrated backlight or what? Is it hard to remove? I've checked fuses and all seem good. Sensors in the doors? Thanks
Old Jan 21, 2010 | 10:38 AM
nanatonzy's Avatar
99 ML320, 97 E320
did you find an answer to your question yet? i have the same problem.
Old Jan 21, 2010 | 12:52 PM
Spicoli's Avatar
Ml320
Yes I did. Just pull off the knob in the center of the console, I think it's the temp selector, and you will see the bulb. Access is straight forward but to remove it I used a small piece of tubing that fit snugly over the bulb. I was amazed that the one tiny bulb lit the entire console but it does!
Old Jan 21, 2010 | 03:51 PM
Boston Mark's Avatar
1998 ML 320 1975 450 SL
Thanks Spicoli!
Boston Mark
