ML430 will not start unless engine is cold PLEASE HELP
Here's a link on how to change it.
http://www.peachparts.com/Wikka/M112M113CPS
Good luck.
Good luck.
http://www.youtube.com/watch?v=MbS_Si106AI
However I see that autohausaz.com has the Bosch for the ML for $42. That is a bargain.
If it is the two pin connector lock then look under ML 320 or call them. That one is $54
and is also Bosch. Shiping from AZ to CA is two days. Add an oil filter and it is free shipping if the order is over $50. If you need the two pin version
then it will be over $50 and you won't need to add a filter for the free shipping.
brakes...brakes...brakes
alternator
idler pulleyx2
serpentine belt x2
battery
tons of oil
soon to b a power steering pump
most recent is crank shaft sensor
...sure is pretty though!
the pump was damaged. It is things like clamps, hoses and seals that were recalled.
Our third recall for more an improved recall just came a few months ago on a ten year old truck.
