Door Panel Removal
Could someone give me step by step instructions.
first remove the wood piece thats on the door handle. ( where you would hold the door from the inside and close it ) remove that piece thats in the middle. after that you'll see 2 screws. remove those. then using like a thin like metal piece or one of them door panel remover start from the buttom of the door.slide it under the cracks and just pop it off by pulling it. there should be about 8 snaps behind there. after popping all those snaps push up the door panel should come off. very easy job.
