Starting/Power issues - alternator???
Old Nov 21, 2009 | 07:37 PM
sandmobdesign's Avatar
ML320
Hello, new here, seems like a highly knowledgeable place.
Anyways, today my 2003 ML320 decided to not cooperate. I was driving and all of a sudden, one by one, every light indicator on the bottom of the dash came on starting left to right. Then the radio turned off, windshield wipers turned off, the A/C kept running, and then leaving the light it would not switch gears. I pulled over to the side, turned the car off. I went to turn it back on and nothing happened. A/C blew, lights worked, radio worked, but the car would not even try to turn over. My girlfriends Dad came to jump me, hooked up the cables and voila! It started! He followed me back home, the minute I applied the breaks it started all over again, I made it home, turned off the car, and then I came back to where I was before her Dad jumped me.
Any idea as to what this could be?? All the shops are closed now, I believe I will give Alex Rodriguezes shop in Clear Lake a shot, I am not too happy with North or Greenway.
Thanks!
Old Nov 25, 2009 | 09:19 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Alternator failures are rare. Most likely its a bad battery. If it is the original change it out. If its recent have it tested by a competent shop under a load. New batteries can fail also.
