2001 ML430 will not start when engine is warm
Old 12-18-2009, 08:19 PM
Racerx18691's Avatar
Mercedes ML430
Please help! My ML430 will only only start when engine is cold. Once it is warm, it will not start again until engine is cold again.
I have heard this could be a crankshaft position sensor (CPS) or a mass air flow sensor (MAF)
which is more probable cause? thank you.
Old 12-20-2009, 01:36 PM
kfriceman's Avatar
2009 ML350
CPS is most likely the culprit, pull the codes and you will know what is is exactly.
-Kevin
Quick Reply: 2001 ML430 will not start when engine is warm
