Full W163 transmission fluid change
Use transmission fluid that is spec'd 236.12 or 236.14. There is some older fluid out there that dealers will try to put off on you that is 236.10. DO NOT USE IT!
Don't do a flush. Drop the pan, replace the filter and refill. It'll take about 3.5 liters (4 qts.) to do it this way. In 30 to 40,000 more miles, do it again. That way, you're not changing all the fluid at once on an old transmission.
cmitch whats the reason to avoid the 236.10 fluid? Thats the only one I can find online at a decent price of $10-14 /L the dealer has the 236.14 but the cost is $22/ L.....
Anyone have a good source for MB parts in canada?
Shalil
1988 300E, 1994 E320, 1999 ML 320, 2002 SLK 32 AMG -SOLD-, ML 350SE -REPOSSESED-
Cut the crap go to an auto parts store and get the Mobil 1 ATF fully synthetic fluid. As Anthony Bourdain says the good stuff...
I wouldn't mess with the factory crap if you paid me. My money is on the Mobil 1...
Its just under 9 bucks here in the states. At Canadian prices it should still be cheap compared to dealership costs. Trust me.
Don't forget to turn the crank and drain the torque converter. There's a crush nut/washer in there that needs to be changed as well. Measure how much fluid you take out and put back exactly what you drained out. That's very important!
And about the parts issue buy them on the internet and be careful who you buy them from. Shop around basically...
#33
Well, once you refill it, you start it up and cycle through the gears without driving the vehicle, this allows the fluids to move around and refill the TC, once you do this, remeasure if you using the dipstick method and then you should be good to go!
#35
Pictures are very helpful for this job, thanks!
The transmission here is one of the last things I plan to tackle on mine. Seems like an easy job and I've done transmissions before as far as fluid changes go.
My smaller clicker wrench happens to range from 3.6Nm to 25Nm so, good to go there. Picked up the t-30 and 5mm hex sockets. I've had 10liters of the MB genuine ATF fluid sitting around for a few years now haha. Went to the dealer the other day and picked up the pan gasket, oil filter, pilot bushing (I have the leak issue), drain washer and red cap.
I've had the leak for quite a bit however, a while back I cleaned the wires leading to the TCM and the actual TCM itself to prevent damage and occasionally I have removed the 13-pin connector and cleaned that as well.... until I complete this job.
Never had any transmission problems, irregular shifting, "limp mode," or any other crap.... maybe my 722.6 was one of the select few lol.
and in case you guys were wondering... no, mine isn't AMG =P
I had to replace all the brake lines, hoses, and calipers... so I figured I'd paint them red too while I was at it. Custom bending lines and fishing them through the vehicle can be a pain. It is what it is haha
#36
So, it's okay to start the car with no fluid in the torque converter? is there any risk of damage? I have a 99ML430, there is a drain plug for torque converter; but I'm a bit anxious about starting it up with no fluid in it. Any advise is appreciated.
#37
Hi dipinj,
I believe it would damage the transmission.. In my Pontiac I drained it first, changed the filter and put the pan back put new ATF fluid. Next opened the hose of the Torque. Converter on radiator side and kept adding new ATF to it until fluid from torque.Crt became clear from its old black and dirty color ..then I stopped and plugged hose of the Torque.Cnvrt back to the radiator.
Note: Most of the US car radiators have a little compartment on the passenger side of the radiator that ATF circulates to cool down... it comes from TC.
I Hope this help
I Hope this help
#39
2002 ML 320 & 2006 ML500
#40
Thanks so much Dundee..
Then for flushing the T.C what would be the alternative? shall I open the Transmission hose hose on Radiator side and drain it that way? or just change the filter and add 4-qt of fluid and that is it.
Best,
Best,
#41
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
How many miles since your last change (if ever)?
I did mine from the hose on radiator on C230 after doing the pan and filter. Did it twice. Once at 120 and once at 180K.
230K and tranny still feels tight. Do the Orings on connector while you're down there.
Have a write up on the 203 forum you might find helpful. Same trans.
The reason I ask how many miles, is according to most mechanics replacing all the fluid on an older trans is a bad thing. But so far not an issue for me.
FYI- If you want to DIY, so much easier to have a lift,
you can rent a a spot at a place called Pit Row in Santa Clara.
#43
fastnoypi (03-24-2016)
#45
IS THE TRANSMISSION OIL DRAIN PLUG A LEFT HAND THREAD? That is, does it loosen by turning clockwise? About the change the trans oil on my ML350 W163 2003 and I don't want to strip the thread if I can help it! Seems tight using a 5mm Hex Allen key either way.
#46
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
It's 6 x T30 for the pan -- drop the whole thing
#47
On the W163 350ML, the gasket pan plug definitely has a 5mm hex plug (see #9 in this thread). And you are correct we47b1, the pan is held on with 6 x T30. The 5mm hex drain plug is so tight though, and will not budge (I'm concerned about damaging it) , so I did wonder is it was a leftie! I think I'll get a 5mm hex for a 3/8 socket and see if that is any better. If not, I'll order a new plug (Any suggestion as to where I could get one other than the MB dealer?) and drop the pan to change the filter and oil, and attempt to extract the stubborn plug so its an easier job next time. Its a very low kilometre vehicle. We bought it 3 months ago with only 52,000kms, and have just turned over 60,000kms now, and although we have the service book records from the one pervious owner, they are not very specific and don't show if the transmission oil as been changed. so I though it would be best to do it while everything is running well.
#48
All went well with the transmission fluid change. A tip for others trying this- when fitting the new gasket, make sure the 4 small lugs in the sides of the gasket are lined up with the indentations in the pan. This will ensure the gasket is sitting even and straight and there are no leaks.
