2004 ML 350 Head/Tail Light Replacement
C 230 and ML 350
Recently, I replaced the right directional light in my headlight and ever since it has been blinking faster than that of the other headlight. Any pointers and advice for a newbie? and also, I need a walk through in replacing the brake light in my right tail light. PLEASE HELP! Because now, my right directional light does not even come on while I am driving. Thanks!
1 Post
1998 ML 320 1975 450 SL
Check and make sure that you have the right bulb and it is in properly.
As for the brake light, open the tail gate, there are 2 plastic bolts on the left and right of the lamp.
After removing them you will need to pop the lamp out.
HOWEVER there is a ball and socket that you can not see because the ball is part of the lamp and the socket is part of the body and you can't see them. Use even pressure to remove the lamp. It should just pop out.
Good luck
Boston Mark
Good luck
Boston Mark
