turn signal bink fast after trailer wiring install
Old Mar 5, 2010 | 08:53 AM
ofhs85's Avatar
02 ML320
I just installed a trailer wiring kit and now both left and right trun signals blink fast. all the bulbs are fine and i tested the wiring with a test light and it is working. i wired the harness right into the factory harness connector and i didnt even use those crimp connectors they supply with the kit. any ideas on how to stop this.
Old Mar 6, 2010 | 04:21 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
The turn signal relays are getting overloaded..
Seems like your trailer lights are drawing too much power....
The turn signal blinks are controlled by 2 (one for left and one for right) relays in the fusebox.
If the current drawn through them is too much, relays will do this - they flip back and forth too fast...which causes the rapid blinking...
In Electrical Engineering, there is a specific term for this behavior of relays...can't remember it off the back...but it is a well known behavior..
Old Sep 18, 2013 | 12:47 PM
StevenHaywood's Avatar
1999 ML320, 2009 Cayenne GTS
Hi
Sorry to resurrect an old old thread, but I have the same problem with high speed flashing - with no trailer attached. I disconnected the harness near the fuel filler hose and the flashing returned to normal... Is this expected behaviour?
