AAM, how much to replace and is this the problem
Old Apr 7, 2010 | 09:42 AM
Epagent1's Avatar
ml 320
1999 ML 320,Key fob wouldn't function to lock or unlock vehicle, when opened door manually and put key in ignition.....got nothing, not even a click. Battery had power and jump start still yielded nothing when key turned but lights came on and radio would play.
Mechanic say's it is AAM.
Anyone had this experience, and what was the cost to fix ??
Old Apr 7, 2010 | 05:34 PM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Have you tried to resync the key?? Why dont you buy new batteries and try to resync. An AAM is roughly $2K...
Old Apr 8, 2010 | 07:29 PM
SofaKing's Avatar
2007 E350
AAM
THE AAM IS ABOUT $350 AND TO PUT IT COULD RUN YOU A NOTHER COUPLE HUNDRED.
Old Apr 15, 2010 | 05:09 PM
cmitch's Avatar
2002 ML320, 2010 Ford F150
The AAM in his 99 is the first generation AAM and has the DAS (Drive Authorization system) integrated with it so it is very expensive to replace. The AAMII, which is in your car and has the DAS separated from it, is about $350- $400 for the part and the labor to install about what you said.
Old Feb 22, 2011 | 04:26 PM
fjp862's Avatar
2001 ml320
where is the aam module located on a 2001 ml320
