Brakes
Old Mar 31, 2003 | 09:46 PM
mhaskelo's Avatar
2006 ML 350
Brakes
I have a 99 ML. I bought it with 28,000 miles. Car has 36,000 now. Great truck other then dealer incompetence. Mercedes records do not show ANY brake work(including pads). Is that unusual? Dealer says not to worry as the light indicating brake will let you know......thanks.
Old Apr 1, 2003 | 12:07 AM
SteveB's Avatar
ML500
Look at the pads! They're readily visible through the wheels, are they completely worn out, or is there still friction material left?
Wear indicators aren't really necessary if you just look at the pads now and then.
Old Apr 1, 2003 | 11:09 PM
timdf's Avatar
ML430, Mini Cooper S and Porsche 911 Twin Turbo
Original owner might have changed the brake pads..
and even the rotors himself - thereby avoiding a gouging by the MB stealership ;-)
Old Apr 22, 2003 | 10:36 AM
klrskir's Avatar
'03 ML500 Sport
LOOK!
Look at the pads. I had a '99 430 and at 31,000 miles the light started blinking. It never went solid, and within 1,000 miles I was chewing the rotor and had to replace two.
