Drive cycle - how to get OBDII ready
1 Post
2007 Mercedes SL550 Sport
driven the car on highway and street over 120k miles and still obd not ready for inspection. scrolling through it says MIL, EVAP & 2AIR are not ready yet. I know dealer has a set procedure to get the computer in ready mode. anyone knows????
04 ML350
04 ML350
obdii drive cycle for a 2002 Mercedes Benz ML
There was a posting at: wiki answers...
http://wiki.answers.com/Q/How_do_you...des_benz_ml500
Here is the procedure I found. However, be aware that conditions must be exactly right to reset. It may take several tries over many days.
The OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another).
NOTE: The ignition key must not be on prior to the cold start otherwise the heated oxygen sensor diagnostic may not run.
1. As soon as the engine starts, idle the engine in drive for two and a half minutes with the A/C and rear defrost on. OBDII checks oxygen sensor heater circuits, air pump and EVAP purge.
2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. OBDII checks for ignition misfire, fuel trim and canister purge.
3. Hold at a steady state speed of 55 mph for three minutes.
OBDII monitors EGR, air pump, O2 sensors and canister purge.
4. Decelerate (coast down) to 20 mph without braking or depressing the clutch. OBDII checks EGR and purge functions.
5. Accelerate back to 55 to 60 mph at æ throttle. OBDII checks misfire, fuel trim and purge again.
6. Hold at a steady speed of 55 to 60 mph for five minutes.
OBDII monitors catalytic converter efficiency, misfire, EGR, fuel trim, oxygen sensors and purge functions.
7. Decelerate (coast down) to a stop without braking. OBDII makes a final check of EGR and canister purge.
