Wind Noise from Sunroof??
Old May 30, 2010 | 01:41 PM
athenshome's Avatar
1999 Mercedes ML430
I've noticed that last few time while driving my 1999 ML430 that I have a good bit of wind noise coming from the sunroof. If I close the blind door, it reduces the noise, but not completely. When you have the blind door open, it is very noise, almost as if it were cracked open.
I would think there is some kind of weather stripping to replace for this solution, but any help correcting this is very much appreciated!
Old May 30, 2010 | 05:13 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
W210's of the same era have a sunroof noise issue when the sunroof is all the way open. Kind of a buffeting wind sound from about 25mph to 40mph.
Supposedly to correct it, MB changed the switch to stop at about halfway open. That does work pretty well so you might try only opening your sunroof half way to see if that helps. Not an ideal solution to be sure.
Old May 30, 2010 | 11:18 PM
athenshome's Avatar
1999 Mercedes ML430
I'm sorry... Let me clarify my issue a bit more.
The wind noise I am getting is when the sunroof is closed, not open. I am aware of the wind sound you're referring to, but this issue is just wind noise while the sunroof window is closed.
Thank you for your post.
Old Jun 2, 2010 | 11:52 PM
frogstaple's Avatar
2005 E320 CDI, 1999 ML430
I have the same problem in my 99 ML-430, as if the factory glass does not match the contour of the roof. It's annoying.
