Front end creak
2014 CLA250 Coupe 4MATIC C117
Front end creak
Have a very annoying front end noise, a loud creaking at slow speeds, coming from the passenger side, directly behind the front wheel, but very hard to pinpoint. It disappeared during the colder months, but has re-appeared now that the weather is warming up.
I had the front shocks replaced, but this did not solve the problem. I have used silicon spray to the obvious bushing locations, but must not be hitting the correct spot or it is just not the problem. Also, it disappears in the rain.
Any ideas or references to threads is appreciated. Thanks,
Kevin
Kevin
1 Post
His mama. Traded y0 mama in because she was squeaking.
Lower Control arm bushings?
Upper control arm bushings?
It almost sounds like a bad bushing somewhere. Noise goes away when the bushing gets wet, comes back when dry.
ml55amg
Its quite an annoying sound and a bit embarrassing....
