changing spark plug wires on ml320
Old Jul 17, 2010 | 08:42 PM
medmac's Avatar
99 ml320
What is the best or approved method of removing spark plug wires from the coil box (?) when changing out the spark plug wires when changing plugs? Also should anti-sieze compound be used on the plugs?
Thanks in advance for any info.
Old Jul 26, 2010 | 09:37 AM
Benzo 003's Avatar
2008 ML350 4matic
spend the few dollars on a 17mm plug wire tool...eBay. I would stay away from the anti-sieze....not necessary.
http://cgi.ebay.com/ebaymotors/Merce...motiveQ5fTools
Old Jul 26, 2010 | 01:00 PM
lkchris's Avatar
'10 CL550, '12 GL550
The wires are $35 each from a dealer and you have 12 of them. They are replaced only when required, and then replaced individually. It ain't a Chevy.
