Sunroof Weatherseal Replacement
Old Aug 31, 2010 | 07:10 AM
Black_magic's Avatar
Hi everyone,
When I take my ML430 through the car wash, the sunroof leaks under high water pressure. I checked my drain holes and determined they are working just fine. The problem is that the weather seal (felt and rubber strip wrapped around the sunroof glass has degraded somewhat, leaving a gap big enough to allows water to get into the cabin).
The part costs $153 but for the life of me can not find instructions on how to install it.
Any ideas?
Old Sep 10, 2010 | 07:58 PM
black mercedes's Avatar
2000ml320
My ml320 has begun to leak through the sunroof when i takes it to the car wash. Like black Magic i am hoping that some of you guys can help us. Thank in advance.
Old Mar 23, 2011 | 11:34 PM
Arthur Gardner's Avatar
2008 E320 CDI; 2001 E320; 1949 Cadillac; 1956 Cadillac
I have a similar issue on a 2001 E320. Did you ever figure this out?
Old May 10, 2011 | 11:41 AM
Redwingedfreak's Avatar
2004 ML350
I just started to have this problem on my 04 ML350... but I take it from the lack of responses that there is nothing new to add. I'll keep looking anyway, thanks.
Old May 10, 2011 | 12:59 PM
Leaky roof
On my 01 E320, the problem is that the sunroof pan ("cassette") has rusted out in the corners, destroying the pan's ability to channel the water through the drain hoses and out of the car. So now the roof leaks into the car any time it rains.
I don't understand what caused the roof pan to rust -- apparently this is extremely rare. Dealership wants over $1K just for the part. I might try to get a used one, since they don't seem to go bad that often. The real issue then is the size of the repair job to replace it. You have to drop the headliner to replace the pan (and to replace the rubber seal around the roof panel). To drop the headliner means dropping the coverings at all 6 posts as well. There is a post here somewhere about how to drop the headliner -- I printed it out in case I work up the nerve to tackle this job one weekend. It looks like it would take me a day or two. Ugh!
