ML320 starts, runs, then dies
Old Sep 19, 2010 | 11:37 AM
Kestas's Avatar
95 E320 Cabriolet, 108K
1998 ML 320, 120K
My friend is having a problem with his ML 320. It starts, runs for a few minutes, then dies. Familiar to anyone? Where should I look for the problem?
Old Sep 19, 2010 | 04:18 PM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
You say it runs for a few minutes. If it runs for 1-2 seconds then it is the Key's DAS (Driver Authorizing System) and you have a bad key. If it runs for a few minutes then you could have one of several problems. One is a bad fuel pump another is a bad CPS (Crankshaft Position Sensor) or any of several other issues. If it's not the Key then you should get the ODBII codes read.
Mike
Old Sep 26, 2010 | 06:08 AM
jotaeres's Avatar
Mercedes Benz ML320 1999
Hi, I'm new here. I had the same problem and I'd fixed it replacing the fuel filter.
Old Aug 29, 2021 | 05:22 AM
ken mullard's Avatar
ml320 w163 2001
Mike
w163 dies 2 sec after starting
Old Aug 30, 2021 | 02:20 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must scan for codes in all modules .
Amazon Amazon
