is Power steering radiator necessary98 ml 320
The PS rad was leaking so my mechanic cut the hoses and by passed it.
Running without PS radiator and using generic PS fluid.
Seems to be OK.
Whats the down side to running without PS Radiator?
98 ml 320
Seems to be OK.
98 ml 320
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Are you certain that the PS rad was leaking and not the trans cooler?? Doing what you say will eventually cause the unit to fail if by not using the MB fluid alone. I am not even certain that the PS unit has a rad.
