2g430..."roof rack pop"
2000 ML430, 2008 GL550, 2008 F250 Superduty, 2007 VW Jetta
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
the dealer had it again for another two days and nothing. they thought it was my rear bumper, then they replaced my rear shocks and still no luck. at the moment, im just trying to ignore it. the sound is something like a "poping" noise that only happens when i make a turn into a steep driveway or something. at least thats the only way i can reproduce it. im thinking of taking it to another dealer when i get my oil changed, which is due in a few hundred miles. is your's doing this too?
1998 ML 320
Mine is not doing what you described. Then again, I have put only 1k miles on mine and that is only weekend driving. I will keep an ear open when I start driving more frequently.
The problem I was having was when I go over large bumps, it seems like it is dropping very hard in the back. The service says the shocks are fine. It only happens on very large bumps though.
Have you had any other trouble with your ML?
1999 ML430
I had a similar problem, a slight pop when making a sharp right. It had to do with the suspension flexing. I was able to fix it by spraying the front torsion bars with a silicon. I was referred to a website by a very knowledgable ML guru. To really do it right they suggest having bushings installed. I have not done this but, the pop is gone with just the spray. Here is the web address.
www.4x4abc.com/ML320/ml320_torsions.html
Give a shot. I hope this will help.
