Oill level Sender
Old Dec 10, 2010 | 11:14 AM
alienmercedes's Avatar
Oill level Sender
I have a faulty oil level sender. I see that it is difficult to replace. My question is does this only warn you about levels. I am concerned that a sudden loss of oil pressure would not be known. I was thinking of disconnecting this sendor since it is reporting low levels when they are not but I still want to be advised of low oil pressure. If I can do this could someone also tell me where the wires are located on the engine so I can disconnect them. Most cars do not have this feature but they all have this warning light for pressure. thanks in Advance.
1999 ML320
Old Dec 16, 2010 | 07:43 PM
Mbzdoctor's Avatar
e350
no that is not for oil pressure, only level. you also have a dipstick so you don't have to depend on the oil level sending unit. replacing isn't that difficult, you only need to remove the sub pan.
