blower fan heater/air conditoner problem
1999 ML 320
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
ok, i've had a problem with my blower since last summer. symptom is when i have the setting with a/c on all the way to cold(blue), the vents will blow super hot as if i have the heater on. the same scenario happens when i have the setting in the middle(blue and red). i have had the a/c system re-charged. still, the same symptom happens. it's a '99 ml320 if it matters. any help would be greatly appreciated.
ML430
air blend motor or heater valve. you can diagnose the air blend motor easily just by listening. If it sound like a clock is ticking when you move the temperature switch from hot to cold then it is the air blend motor. a more complete diagnosis can be done by removing the dash glove box and in the left corner behind the metal tube is a plasic linkage and metal arm. you can view the operation of the motor. if it moves all the way foreward and back it is ok. if you can push on it and it moves more it is bad. However it could be a bad electrical connector and not the motor. Motor costs less than $200. labor is about $1200. involves taking the dash out.
01 S2000, E46 M3, 99 ML320
I think it might be this blend motor
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Is there DIY instructions on how to remove the dash? My mechanic said I can save some labor if I take the center console and dash off....
thanks!
