Please HELP! ML320 throwing 302 misfire
Old Apr 26, 2011 | 09:59 AM
mz0dw4's Avatar
ML320
New to the forums. great place. Went out and started my ML320 the other day and was misfiring causing an obvious shake. Got my OBDII and scanned it came up with a 302 Cyl 2 misfire. Shut it off hoping it would start back up and work OK, no luck. Took it to my mechanic, so far we have replaced the coil pack and fuel injector (said it was reading wrong resistance). He uses Alldata and I trust him. He said this.... "the new fuel injector is getting 12v, but not getting the negative pulse from the ECU". He theorizes that the computer has a problem, possibly a driver issue causing it not to send the pulse to the injector and is recommending a new computer if all of the stuff below does not work? I, (knowing nothing) theorize after reading many posts in this forum that it is another problem causing the ECU to stop the pulse from being sent to the no 2 injector. The next thing we are replacing is the crank position sensor, and cleaning the MAF sensor. Here are the next questions I need help answering from the experts. After all of the work, is there any procedure that needs to be done before it will fix this issue? i.e. computer relearn, etc. I welcome any suggestions, advice, on next steps if this does not work. I am scared that we are as far my mechanic wants to go and I will have to take it to the dealer. Please help. Thanks
