need to locate a remote wire...
Old Jul 11, 2011 | 02:09 AM
r_ishmael's Avatar
2000 ML430
I have a 2000 ML430, with the Bose system. I have a 12" sub and a 300w amp that i am planning to install. Now i just need to find a igntion wire for my amp, i can't remove the head unit, so does anyone know an easier way? Would i be able to use the cigarette lighter instead? any info/help is greatly appreciated, thanks!
Old Aug 11, 2012 | 11:39 AM
SteveOH's Avatar
ml350 2009
How on earth I have spent 4 hours searching for this (seemingly) magical question
I have a 2009 ML350 w/HK Sound System.
I want to connect an aftermarket amp and sub (bypassing the stock sub)
I completely understand how to connect the audio wiring specs.
H O W E V E R
WHAT FUSE DO I TAP for the on/off remote wire comming from the aftermarket amp???? I need a fuse that simply turns off when key is removed from vehicle. Every fuse ive tested (so far) has a delayed shutoff and this is driving me insane.
I DO NOT WANT TO USE A line out convertor OR ANY KIND OF THIRD PARTY Sound Sensing devices.
HELP PLEASE ive been searching these forums for 3 hours and no one seems to have a direct answer to this question
Old Aug 11, 2012 | 04:11 PM
gsfent's Avatar
W163 ML500 w/Kleeman headers (gone but not forgotten); R63
H O W E V E R
Cig lighter or window switches? Would only take a minute to confirm no power when key is out.
Regards,
Jerry
Old Aug 12, 2012 | 05:23 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
H O W E V E R
That is because you are on the wrong forum. You should ask your question on the W164 forum.
Old Aug 12, 2012 | 11:54 AM
SteveOH's Avatar
ml350 2009
Thanks for the reply
Yes I understand that the power windows of cigg lighter would be the best way to go, however I have tapped these lines in the past and experienced weird battery drain.
Seems like theres something about the SAM Module (Signal Acquisition/Activation Module) that changes how the accessory fuses behave. Like anything connected to it seems to have a delayed "shut off" even after the key is removed.
I have never tryed to tap directly into the cigg lighter - meaning litterally tap the wire behind the ashtray itself. Im wondering if this would be the best way to go.
Can anyone shed some light on this?
