ML 270 Brake Switch
Old Aug 20, 2011 | 02:17 AM
wooders's Avatar
ML 270
ML 270 Brake Switch
Hi all, have a problem with the ebd abs lights on the dash, looked to replace the switch, and it was not there on the bracket by the foot brake. Is there a secondary location, as unless the lights work by magic I'm stumped as to where the switch is !!
Kevin
Old May 21, 2012 | 09:01 AM
binbenz's Avatar
ml350
Kevin
hi kevin
if i'm not mistaken its attached to the brake master cylinder,its a high pressure brake switch,,real easy to take off and replace ..look at your brake master cylinder and underneath the reservoir you will see the switch with a wire attached,unplug the wire and remove the switch,24mm spanner takes it off..careful not to cross thread it when replacing ..
