1998 ML320 stalled
Old Oct 24, 2011 | 08:25 AM
claylcary's Avatar
1998 ML320
1998 ML320 stalled
My truck was stalling occasionally over the past week. It stalled Saturday and will not start. Does anyone know the fuel pump pressure spec? The starter just kicks over with no response.( stays on until you kill the key) The check engine light is not on. I have a two error codes present 432 and 460. One is catalyst threshold low and fuel level sensor) (gauge sticks sometimes) Please help
Old Oct 24, 2011 | 05:16 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here is the info. on fuel pressure. If the fuel pressure checks out OK then you will have to take a look at the RMP scale on your scanner. If it shows approx 250 RPM while cranking then that is a good indication that the Crank Position Sensor is OK. If there is no reading the change the Crank Sensor.
File Type: pdf
