ML Noob Questions
Picked up ML55, just had two questions, is there no ground cover at all? Like a shroud to cover up under the radiator?
Also, just noticed my HVAC is not lit up. I am assuming it is supposed to and a bulb needs to be replaced(Found the Part # via search). How involved is this?
TIA!
Pull out the center knob on the HVAC unit and you will see the bulb. Get a small piece of vacuum hose smaller than the diameter of the bulb. Force it over the bub and then pull the hose and the bulb will come with it.
