2001 ML55 Overheating
When I turn my A/C on the fan does come on and my temp goes down to operating temperature.
What could be causing my ML55 to over heat?
Why doesn't the fan come on when the temperature rises to high?
Thank you.
Thank you.
Either search, or perhaps someone here knows which switch/relay is most the likely culprit. Most often the replacement is DIY.
Regards,
Jerry
If the fuse is OK, then you must conduct tests at the ECU for the Coolant Temp. Sensor. Do you have a DVOM?
Did you look at the photo above?
I will try to get pics, but may not be able to until this weekend.
