my shufter is stuck on the plus side of the tronics
Remove the arm rest lid.
Remove stowage box.
Pry off shifter trim.
Remove window switch module.
If that is the case you have a problem with the electronic shifter circuit. I you want, you can remove the shifter, disassemble it and clean the board with electronic contact cleaner. I still say there was some spillage before you bought the truck which is preventing proper contact inside the shifter.
