2001 ML320
Explain what your problem is.
The dealer said the pump cannot be opened and just has to be replaced--no mention of an O-ring.
You never mentioned it so I have to ask. Have you checked the fluid level?
Are there any noises while turning at 700 RPM's?
Order a new reservoir from M/B, approx. $20 and a new O-ring, but don't order the pump as yet.
Remove the one bolt (female torx) securing the reservoir to the pump and then remove the C-clip..
Install new reservoir and fill the reservoir with fluid. Do not start the engine and perform the bleeding procedure as outlined in the pdf. Raise the two front wheels off the ground and turn the key to pos. #2 and while someone slowly turns the steering wheel from one end to the other. You look into the reservoir while the person is turn and when the air bubbles stop the procedure is over.
If this does not correct the condition then replace the P/S and the only thing you will have to do is remove the reservoir and transfer it to the pump, but remember that the bleeding procedure still applies.
