Fuel Injectors stop working
If you have misfire codes on cyl. 4,5 &6 then that would indicate that you have a clogged catalytic converter. When the misfire count reaches a certain number, the ECU will shut down those cylinders to protect the engine and the cat. converter.
Remove the upstream/front O2 sensor on the driver's side and start the truck. It will be a little loud, but if the truck remains running, you need a new cat.
