Can I restore my stock rims?
Old Feb 20, 2012 | 06:38 PM
Skibumtx's Avatar
I have a 99 ML320 with the stock 16" rims. Over the years the finish on the rims has deteriorated and even started to peel off in many places.
Is there some way that I can make them presentable again?
I would assume that I'd need to strip the old finish off and then apply a new finish of some sort but would like to find out the best way to do it.
Thanks,
Ski
Old Feb 22, 2012 | 03:16 PM
Stiggs's Avatar
2003 CLK55
Probably cheaper to buy new rims?
Old Mar 12, 2012 | 05:14 AM
Wragie's Avatar
IHammerheadEagleThrust MK II
I've had/a few friends restore wheels and they each did the wheels a bit differant depending on how much cash they were spending. First stage was always cleaning and stripping. One Guy did a acid bath and the other a walnut blasting to clean them. You can buy stripper in cans at any place that sells auto body supplies if you want to do a DIY. You can get most of the stuff off with that and a wire brush. Hitting it with a blaster after will do a better job. The finish stage is either going to be paint or powder coat. I'd go with the powder coat as it is a bit better at hiding minor damage. Basically this is going to cost you maybe $50 a wheel if you drop them off (your cost will vary :-) ) at a shop but they will basically do some combination of those steps. If you can do some yourself you can save a bit. If you have the time all of it can be DIY including the powdercoat.
Old Mar 30, 2012 | 08:30 PM
abcnus's Avatar
ML430
These rims are painted with the MB brilliant silver paint. Can be done DIY or bodyshop.
