will these offsets fit ML55?
87 190e 2.3l-16v
I found some used wheels for sale. Was wondering if anyone has experience fitting a set up like this on ML55's (oe brakes), or will there be clearance issues?
19x8.5 +45 and 19x10 +40 offset (Carlsson brand)
I would run same size tires all 4 corners. Should be ok stagger as long as you run same tires.
Thanks in advance.
Thanks in advance.
W210 - V6'02 / W163 - V6'02
if not mistaken the offset on standard wheel is 46... so shouldn't have any clearance problem.
would recommend to check with tire rack website to get the right tire size for stagger set bcoz it's the overall diameter (wheel + tire) that is matter, so your front tire maybe diffrent than rear tire.
