ml230 loose power
I really need help with my mercedes ml230
I have a problem of loosing power while going uphill.
Problem description: at idle the engine shakes too much and when i press the gas pedal the response is not immediate and it shakes first then response.
if i stop in the middle of uphill and try to drive the engine almost dies and can't go on untill i press the cluch and leave it again.
Solutions they tried at mercedes official garage :
they changed the following parts :air mass sensor, injectors, camshaft sensor, spark plugs, oil, oil filter, air filter, Throttle, ECU and at last they changed the whole engine. they also checked the pressure at the fuel pump and it was 4 PSI i think not sure, they also adjusted the timming chains.
Nothing helped... i don't know what to do they say that it is a problem that i will have to live with but its a problem that you can't live with and i also need my mercedes to drive like a mercedes.
i really appriciate it if anyone gives any suggestions because i'm ready to do anything in order to fix this problem.
thanks
