98 key transponder
98 ml320 american
Starts and stalls after 1-2 sec
Looked to be key related
Bought new keys @mb 2x, keys were ordered by vin
Still the same (both keys + the one that came with the car)
note: red led next to radio does not light at all
Should it light/flash even if key/transponder is bad?
If it doesnt light and key is good, does that mean transponder ring is bad? or could it be worse (ecm)?
Is there any way to be sure without towing it to MB?
Dont want to spend another $170 on this thing based on a blind guess (this is getting expensive)
Any help out there?
I also pulled the starter and lubed the gear and shaft but that didn't work.
http://www.youtube.com/watch?v=H7bks...ature=youtu.be
Is this the AAM problem you described?
Thanks for any suggestions.
