02' ml500 shut off at stops
Old Nov 4, 2012 | 09:16 AM
zander01's Avatar
2002 ml 500
Owned a 2002 ml500, vehicle shutoff when comming to a stop, restart then repeat at the next stop. Change fuel filter before this problem, change crankshaft position sensor after this problem, nothing changed. NEED SOME ADVISE !!
Old Nov 4, 2012 | 09:27 AM
Vander's Avatar
2002 E55 AMG, 06 C55 AMG, 72 350SL
Is it throwing a check engine light? Could be idle control valve, sounds like it has trouble idling while at a stop.
Old Nov 5, 2012 | 07:49 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Vander, ML's do not have an Idle Control Valve.
Old Nov 6, 2012 | 06:49 AM
Vander's Avatar
I thought that shortly after I made that post.
Old Nov 6, 2012 | 06:50 AM
Vander's Avatar
Shuts off while idling, curious as to what it is.
Old Nov 7, 2012 | 06:07 AM
Usually this problem is attributed to a faulty CKP (Crankshaft Position Sensor) which he already replaced. But he has not responded to your question of whether the CEL is on or not.
Regardless, a code (P0335) will be stored. Possibly he purchased a knock-off sensor which will be useless.
Old Nov 11, 2012 | 08:51 PM
zander01's Avatar
2002 ml 500
Shutoff problems
Hey guys, sorry for not responding earlier on that shutoff problems. At the time of the shutoff problems no CEL was on. However, I change the trottle cable today, take the car for a spin and the CEL is on but the suv is not shutting off anymore. I wonder if the trottle cable was the problems. The dealer did a diagnostic about 2 months back and stated the trottle cable broken and need replacement, but I went on road trips from Houston to Chicago and also to Florida and no problems. When I change the trottle cable I do not see anything broken, but then I am not an expert. I will check out the code on the CEL in the coming days. The dealer also recommend to change the filter pump also, I might just go ahead and change pumps anyway. I need some help on the easy way to change the fuel pump. Thanks for the respond guys !!
