2007 ML350 Check Engine Light with codes P2004 and P0128
Old Dec 29, 2012 | 02:30 PM
evo99's Avatar
91 SL500 & 07 ML350
Check engine light on my 07 ML350 came on. Read the code and it's showing P2004 (Intake Manifold Runner Control Stuck Open Bank 1) and P0128 (Coolant Thermostat coolant temp below thermostat regulating temperature). What is the chances that both became bad at the same time? Could one code affect the other to fail? What can be the root cause of these defects and what can be done to fix these issues? Thanks.
