2000 ML430 Passenger Seat not working...
Old Jan 25, 2013 | 11:44 PM
kidriot's Avatar
ml 430
So my passenger seat has stopped working. I checked the fuses, and they're good. I've heard they are really finicky if something is blocking it.
Does anyone have any ideas?
Old Jan 26, 2013 | 06:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Does the heater switch illuminate when you press it? If it doesn't then it could be the switch or the EAM (Extended Activities Module) which controls the heated seats. If it does illuminate then ▼▼▼
It is not a fuse issue because Fuse #8 supplies voltage/current to both seats. The only thing you can do is unbolt the seat, tilt it and access the two relays (stage 1 and stage 2) which are side by side. Check to see that the connectors to both relays are in place.
If so you will have to buy one relay from the dealer and with the key out of the ignition, swap one relay at a time and see if the system works.
