2000 ML430 Help
Old Mar 19, 2013 | 05:54 PM
emil22's Avatar
ML 430 2000
2000 ML430 Help
anyone know where I can fix/reupholster my seats and the interiror of my car?
also anyone know where I can fix or get a new navi/radio system? I prefferably want to get the same navi/radio system but if anyone has better recommendations please lmk.
also my car has problems as well:
1. my A/C is broken. it blows out hot air not matter what. even if i try to turn it off my A/C blows out hot air. a mechanic said itll cost about $2000+ cause he has to open up the compressor? want to know if thisis right.
2. Theres a hissing sound on the drivers side evertime i turn on the car.....a mecanic said its a brake booster and was charging $1100.....want to know if this is fairly priced
Old Mar 20, 2013 | 01:17 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The upholstery problem is the least of your concern.
What is wrong with your radio?
https://mbworld.org/forums/m-class-w...akers-etc.html
As for the A/C problem, you must replace your Blend Door Motor to correct the problem. The top half of the instrument panel must be removed to do so.
The hissing sound is a faulty Brake Booster and also must be replaced. I would suggest looking for a used one at a junk yard and have it installed.
Where do you live?
