SRS light stays on with amp install - help
I just installed a new sub amp into my 430. After the installers completed the job the SRS warning light comes on and stays on constantly. Installers said they don't have the equipment to reset. Anything I can do - or is this a dealer fix? Thanks in advance. - Doc
You're thought about the SRS harness is interesting - is this a harness that is easily seen? Thanks again.
I did take it to dealer - they said they found the wires cut and wanted to charge me $575.00 to rewire - I said no & that I would go back to the install shop. Dealer still charged me $312.00 to "diagnose" the problem.
I plan on making the install shop pay for the charge and fix the problem. They did fix the problem which they said was the connector that was not plugged in so the SRS light is now out, but no word on the reimbursement yet. For cryin out loud - if they would have found the disconnected connector in the first place....jeez. I'll keep you posted.
Thanks again. Doc
