A/C Compressor Not Engaging?? Troubleshooting
Old May 4, 2013 | 09:24 AM
athenshome's Avatar
1999 Mercedes ML430
My '99 ML430 a/c compressor is not engaging and I cannot figure out why yet. I have enough refrigerant in the system and the compressor is not seized (can spin the clutch freely by hand), but I'm getting nothing from it when the system is running.
Can anyone help me with troubleshooting this compressor problem? I was thinking maybe a faulty pressure switch or unplugged power line, but I'd just like to try and determine the problem without removing it from the engine, if possible. I also apparently have a oil leak that has sprayed all over the place and made it pretty messy down in this area.
Any help with this diagnoses is greatly appreciated!! Thanks in advance!
Old May 5, 2013 | 01:23 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please answer the following questions:
1. when you press the AC button, does it illuminate?
2. how do you know that there is sufficient refrigerant in the system? Be specific, no assumptions or guesses.
Old May 5, 2013 | 08:35 AM
athenshome's Avatar
1999 Mercedes ML430
Yes, the A/C button does illuminate when pushed on.
I connected a PSI guague to the low port and pulled 36psi, which I thought was correct?
Old May 6, 2013 | 01:34 AM
Please read about Static Pressure.
90% of AC systems not working after change of season layovers are attributed to loss of refrigerant (small leak).
You are probably low on refrigerant, as the system will not operate if the pressure is too low or too high and you should have it repaired professionally.
File Type: pdf
Old May 6, 2013 | 06:08 PM
Vander's Avatar
2002 E55 AMG, 06 C55 AMG, 72 350SL
As for the oil leak, I would clean up the mess with brake parts cleaner. Then drive the car a little bit and see where it is coming out from. It is going to be harder to diagnose where oil is leaking from, when there is already oil all over the place.
Old May 27, 2013 | 11:00 AM
athenshome's Avatar
1999 Mercedes ML430
LEAK FOUND
I found the leak in the A/C last week. Looks like it is coming from the expansion valve. Going to let the new refrigerant I have drain out then replacing it when it does.
As for the oil leak, a guy from Aamco said what we figured (oil cooler seals), so I replaced the seals. I've only driven the car a little bit since and plan to more this week, but it seems that it is still leaking somewhere. To note: the oil expansion cover at the timing case has been replaced and now the oil cooler seals replaced.
If anyone has any suggestions on this, I'd greatly appreciate it. This has been very hard to find!
