2000 ml320 tranny flush
Some people do like a BG flush, that costs more, and is more radical. I'm sure there are cons and pros to that. Drain and fill is less intrusive, you just have to use the proper fluid. I wonder if it's possible to get a dip stick for the tranny, did they even make those?
3 notes.
1. Secure the 'loose end' of the return hose either with a helper or a clamp so it doesn't 'flop around' when fluid flows.
2. First replace the amount of fluid drained at the start of the procedure, or 5 liters. Set-up the 'pump and drain' items. EDITED: See attached AR27.55-P-0100A Flush out automatic transmission and torque converter
3. About the dipstick. Insert it into the tube until it stops - there will be excess length. See included photo.
The dipstick is universal to different lengths of guide tubes w/different vehicle configurations. The distal end has a small triangular protrusion near each end - that is stopped by the design of the guide tube near the valve body.
To understand it for yourself - while the pan and filter are removed insert the dipstick until it stops. Then you can see how 'deep' into the pan it protrudes, and the 'how far in' question will be answered in living color.
4. On attached 'Check Oil Level' the note between #9 & #10 indicates no need to check fluid level hot unless: "Only perform steps 10 to 14 if shifting problems occur."
Last edited by Jerry Easley; Oct 1, 2022 at 06:29 PM. Reason: clarity, updating, added attachment
