1999 ML 320
Old Jun 20, 2013 | 05:44 AM
lynanu's Avatar
ML 320 1999
1999 ML 320
Just bought a 1999 ML320 and discovered an oil leak ( red) I can t believe it ... its not that bad but after looking on the threads it looks to be gearbox leak does this mean I have to have new geabox .. only had the thing a week !!!!
Old Jun 20, 2013 | 07:13 AM
lynanu's Avatar
ML 320 1999
Bump pleaseeeeee
Old Jun 20, 2013 | 11:31 AM
psnevets's Avatar
2017 W166 GLE350, 2005 W163 ML350 Special Edition
Take the truck to an independent that's qualified to do automatic transmission work for an evaluation. Does the truck shift improperly...jerky or slide in and out of the gears? If not, you may only have a leak that should be repairable with fresh gaskets(s).
Old Jun 20, 2013 | 03:37 PM
yourbenztech's Avatar
ML430 E320 S500
Can you be more specific about the conditions for the leak?? consistently? only after driving? what section of the transmission? can you look under the car and see the exact location? how much? any problems shifting?? slipping on low gears?? driving smooth?? shifting hard?? how many miles?? was the transmission ever been rebuild?
