need help with brake lights... stay on
Old Jun 23, 2013 | 07:10 PM
Driver55er's Avatar
w210 e55
My brake/tail lights are stuck on. I looked for a brake pedal switch but there is not one under the dash on my 2003 ml350. No MIL lights on dash illuminated just brake lights on once truck is started.
One post states the light sensor is connected to the base of the master cylinder.
Is this correct?
I disconnected that sensor but the lights were still on. If that is the sensor and I disconnected it should the brake lights have gone off?
A liitle help before I start throwing parts at it.
Old Jun 24, 2013 | 12:16 PM
Driver55er's Avatar
w210 e55
So thankfully I tried switching relays before buying switches or sensors.
That did the trick!
This is the second time i have had a sticking relay. Once it happened with my electric cooling fans and now with the brake lights.
I tapped on the top of the relay and off it went both times.
It was hot and during the summer both times. Maybe they are effected by the heat after they get old.
Old Jun 25, 2013 | 11:33 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Your e-box fan is probably not working and needs replacement.
http://www.keysolutions.com/M-Class....t%26AutoFramed
Old Jun 26, 2013 | 12:46 PM
Driver55er's Avatar
w210 e55
Thanks Maj,
Makes perfect sense also explains loud constant hum from that area that I could not figure out.
Thanks for the link too!
Any ideas on increasing my gas mileage? My vehicle is perfectly maintained but have only 15ish MPG. Do MAF and coils go bad gradually and diminish their performance or are they a working or non working parts?
Truck runs fine no misses fully tune up at 100K
