Tail light gremlins
Old Jul 11, 2013 | 10:06 PM
Avec's Avatar
Tail light gremlins
Wife's ML320 has an obvious wiring issue with the tail lights. When brake lights and a turn signal is on, the brake light on the opposite will blink, and if the tail lights are on, then the back up light will blink instead of the signal. It all points to a bad ground, but I don't know where the grounds are. Can someone point me in the right direction? Thanks
Old Jul 12, 2013 | 04:31 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Having a bad bulb in any location will cause this phenomenon. The ground filament is touching the positive filament.
Old Jul 13, 2013 | 08:22 AM
Avec's Avatar
I believe this situation would actually cause a short and blow a fuse. Regardless, when testing continuity between the tail light grounds and the battery negative terminal there is resistance. I believe a ground needs to be cleaned. Where are those grounds?
Old Jul 14, 2013 | 05:51 AM
Your assumption is incorrect. It will not blow the fuse every time.
As suggested, why can't you simply check all of your bulbs.
Old Jul 14, 2013 | 05:09 PM
Avec's Avatar
Did you read my entire post? Apparently you missed when testing continuity between the tail light grounds and the battery negative terminal there is resistance I have tested both sides and both show resistance.
Please, where are the grounds?
Old Jul 15, 2013 | 06:42 AM
Here are the ground locations.
Old Jul 16, 2013 | 06:46 AM
Avec's Avatar
Thank you. That was the issue, corrosion at the ground stud in the rear cargo area. Oddly, showed zero signs of corrosion, but multimeter showed bad contact, so after cleaning and applying di-electric she is back in business
