ML430 Bypass A/C help
Does anyone know a size/part number for a serpentine belt that can be used to bypass the a/c compressor on a 1999 ML430? If not, is there a bypass pulley available? (have not been able to find either, but, have "heard" they both exist!)
Thanks so much.
Thanks so much.
Hi everyone, probably won't be much help to anyone else, but, I did find the answer to this question, so thought I'd post.
Called the local dealer (should have done this earlier), the parts person did not know anything about a smaller belt spec or a bypass pulley. However, he went the extra step and talked to a tech and the tech went above and beyond to provide me with both a MB partnumber belt and a belt size. They did not have the belt, but I was able to go to AdvanceAuto and bought a really nice belt, the correct size and it actually works! So, without further ado, here is the MB part number and the metric belt size:
MB: 011-997-9692
Size: 20 x 2315 ( this is mm, but it is basically a standard belt that is approximately 92" in length.)
Cheers, Jim
MB: 011-997-9692
Cheers, Jim
